Hi all
I could do with some advise on how to build an Advanced Alert that will give me alerts for lower priority devices, medium and high priority devices with exclusions.
Example:
knwig0004-map320-001
knwig0004-map320-002
knwig0004-map320-003
knwig0004-map320-004
knwig0004-msc3200-gw-001
knwig0004-poepd6506-poe-001
knwig0004-swcat2960-sw-001
The first 4 devices are devices with a low priority, the GW, the PoE and the SW would be the single point of failures for all 4 of the other devices if there was a power failure to the GW, PoE and SW.
So, basically I want to create and alert that tell me if the individual MAP's go down, but it should also tell me when the GW, SW or PoE went down, but then not trigger an alert for the MAP's, since their "failure" is due to the failure of one of the main devices in the network.
Can this all be done in one alert, or would I need separate alerts for that?
