After a VERY difficult upgrade I've got the web interface working again. I have a map that has all my critical devices towards the right side of the base home map. Prior to the upgrade you could see most everything and if you selected the pane (NETWORK MAP) a second window opened and you could see the whole thing as I had set it up with MapMaker. Now the map is truncated at the left and not visible. How do I use network atlas to fix this? I need the whole thing visible on the map. It looks right on network atlas. Guess this was a bit more than a maintenance upgrade :-)
