Has anyone use NPM to monitor a PDU? Is it possible to shutdown a PDU that uses SNMP remotely by running a script prior to receiving a SNMP message?
Hello Steve,
I believe you should be able to do this with SNMP write commands.. I will have a look at my PDU's [Raritan] and see if I can do it.
All the best
hi, ashley.cotter,
how did you write snmp command in pdu? thanks
Hello Juan,
You can call me Ashley no need for formalities.. Erm are you looking at doing the same as Steve, if so I cant remember the outcome of my testing... so I will take another look.
