So when I "connect" one of our Cisco Fusion ASR1004 routers to a Cisco 6509VSS I would like to be able to designate which Port Channel / Interface is represented by the "connection".. yet it appears I can not do that in Network Atlas (nor in Network Topology Mapper).. am I missing something? If I put the interfaces in question on a map and try and connect them I get the "an object on the map is not managed" error... thanks...
