How can you get a list of nodes that are not part of a group in NPM and is this possible through the web interface?
Try:
select Caption from nodes where not Caption in ( SELECT distinct [FullName] FROM [ContainerMemberSnapshots] where [EntityDisplayName] = 'Node' )
your database name might not be "NetPerfMon".
Here is SQL to find that:
select Caption from nodes where not Caption in ( SELECT distinct [FullName] FROM [NetPerfMon].[dbo].[ContainerMemberSnapshots] where [EntityDisplayName] = 'Node' )
You might be able to create a custom SQL report that runs that. I added a SQL experiance to APM that watches the Count(*) for that and sends me an alert if it exceeds 0.
When I run this query, I get the following error:
Invalid object name 'NetPerfMon.dbo.ContainerMemberSnapshots'.
I'm running the RC version of NPM - 10.2. Do I need to run a different query?
Chris
That worked - Thanks again!
