Need someone's help to find ArubaS2500-24P-US CPU and Memory OID and Cisco Nexus (N7K-C7010) BGP peering OID.
We will use the Aruba OID for our CPU and memory reporting while the Nexus OID will be used for alerting.
Thanks in advance.
Herbin
Try to check the standard OID first below post
Multiple CPU Count & Each Load on CPU for the Node
Related Articles.
IF YOU HAVE NO LUCK .
Send me SNMPWALK from both devices (Zip and email me ) as below
Running SNMPWalk
i will let you know what OID"S .
Aruba Memory
1.3.6.1.4.1.14823.2.2.1.1.1.11.1.2 Memory Size
1.3.6.1.4.1.14823.2.2.1.1.1.11.1.3 Memory Used
1.3.6.1.4.1.14823.2.2.1.1.1.11.1.4 Memory Free
Hi Malik,
I have the SNMPWALK of the device, but I am not sure if I am authorize to share this. Can you tech me on how to determine what OID am going to use from the bunch of OID generated from my device.
Hi Petersen,
I used the OID 1.3.6.1.4.1.14823.2.2.1.1.1.11.1.3 Memory Used and the TEST result is OK. But when I assign the OID to our two Aruba devices and waited for several hours, still we are not able to generate a value in our Memory report. Do I have to use all of the 3 OID that you gave me above? We have thousands of Aruba switches in our network and we are testing for these two devices as of the moment.
Are you polling with the Universal Device Poller or did you create a CPU and Memory poller via Settings -> Manage Pollers?
Matthew Hawks
Loop1 Systems
I am using Universal Device Poller found in Solarwinds Server.
I had bookmarked a thread on here myself as i wanted to set up some alerting and this one also relates to the Nexus 7k and 5k
https://thwack.solarwinds.com/thread/60633
Hi lynchnigel,
Thanks for the info, the thread above is about Nexus Health OID. Want also to set-up bgpPeeringstate alert in our network. I have open a support ticket for this.
According to Cisco the BGP peering state is:
"BGP peer table. This table contains, one entry per BGP peer, information about
the connections with BGP peers."
OID is not supported in Nexus devices.
You already asked for an update of MIB this device for the support of SW?Perhaps with this update to resolve your problem.
If you click on the " BGP4-MIB" above it takes you to cisco's site where the MIB is
this also refers where you can download a MIB for the nexus, I think if its not in Solarwind's MIB database, you can submit it for them to include it.
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2
Hi cjfrnaca,
Yes we done updating the latest MIB. Still experiencing the issue.
Hard to say anything without the Walk it would be quicker to answer .
