NPM: 10.6.1
IOS: 03.03.02SE
Orion reporting 'Major' Warning on Temp Sensor 0 and Temp Sensor 1. Temperatures are well within their thresholds though so not sure how to get Orion to show this device in good health.
I have read thread/52727 and checked MIBS .1.3.6.1.4.1.9.9.91.1.1.1 and .1.3.6.1.4.1.9.9.91.1.2.1. The .1.3.6.1.4.1.9.9.91.1.1.1 MIB seems to report accurately and shows OK. The .1.3.6.1.4.1.9.9.91.1.2.1 MIB is hard to understand? Not exactly clear on which values Orion uses or how it interprets them. Is Cisco reporting incorrectly or can something be tweaked in Orion?
Current Hardware Health
TemperatureSwitch 1 - Temp Sensor 0Major14 °CSwitch 1 - Temp Sensor 1Normal21 °C
Switch 1 - Temp Sensor 2Major38 °C
The following is a SNMP walk of device 10.x.x.x starting from .1.3.6.1.4.1.9.9.91.1.1.1
SNMP Walk Output
CISCO-ENTITY-SENSOR-MIB::entSensorType.9 = INTEGER: celsius(8)
CISCO-ENTITY-SENSOR-MIB::entSensorType.10 = INTEGER: celsius(8)
CISCO-ENTITY-SENSOR-MIB::entSensorType.11 = INTEGER: celsius(8)
CISCO-ENTITY-SENSOR-MIB::entSensorScale.9 = INTEGER: units(9)
CISCO-ENTITY-SENSOR-MIB::entSensorScale.10 = INTEGER: units(9)
CISCO-ENTITY-SENSOR-MIB::entSensorScale.11 = INTEGER: units(9)
CISCO-ENTITY-SENSOR-MIB::entSensorPrecision.9 = INTEGER: 0
CISCO-ENTITY-SENSOR-MIB::entSensorPrecision.10 = INTEGER: 0
CISCO-ENTITY-SENSOR-MIB::entSensorPrecision.11 = INTEGER: 0
CISCO-ENTITY-SENSOR-MIB::entSensorValue.9 = INTEGER: 14
CISCO-ENTITY-SENSOR-MIB::entSensorValue.10 = INTEGER: 21
CISCO-ENTITY-SENSOR-MIB::entSensorValue.11 = INTEGER: 38
CISCO-ENTITY-SENSOR-MIB::entSensorStatus.9 = INTEGER: ok(1)
CISCO-ENTITY-SENSOR-MIB::entSensorStatus.10 = INTEGER: ok(1)
CISCO-ENTITY-SENSOR-MIB::entSensorStatus.11 = INTEGER: ok(1)
CISCO-ENTITY-SENSOR-MIB::entSensorValueTimeStamp.9 = Timeticks: (1) 0:00:00.01
CISCO-ENTITY-SENSOR-MIB::entSensorValueTimeStamp.10 = Timeticks: (1) 0:00:00.01
CISCO-ENTITY-SENSOR-MIB::entSensorValueTimeStamp.11 = Timeticks: (1) 0:00:00.01
CISCO-ENTITY-SENSOR-MIB::entSensorValueUpdateRate.9 = INTEGER: 600 seconds
CISCO-ENTITY-SENSOR-MIB::entSensorValueUpdateRate.10 = INTEGER: 600 seconds
CISCO-ENTITY-SENSOR-MIB::entSensorValueUpdateRate.11 = INTEGER: 600 seconds
The following is a SNMP walk of device 10.x.x.x starting from .1.3.6.1.4.1.9.9.91.1.2.1
SNMP Walk Output
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdSeverity.9.1 = INTEGER: major(20)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdSeverity.9.2 = INTEGER: minor(10)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdSeverity.9.3 = INTEGER: minor(10)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdSeverity.9.4 = INTEGER: major(20)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdSeverity.10.1 = INTEGER: major(20)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdSeverity.10.2 = INTEGER: minor(10)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdSeverity.10.3 = INTEGER: minor(10)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdSeverity.10.4 = INTEGER: major(20)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdSeverity.11.1 = INTEGER: major(20)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdSeverity.11.2 = INTEGER: minor(10)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdSeverity.11.3 = INTEGER: minor(10)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdSeverity.11.4 = INTEGER: major(20)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdRelation.9.1 = INTEGER: greaterOrEqual(4)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdRelation.9.2 = INTEGER: greaterOrEqual(4)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdRelation.9.3 = INTEGER: lessOrEqual(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdRelation.9.4 = INTEGER: lessOrEqual(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdRelation.10.1 = INTEGER: greaterOrEqual(4)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdRelation.10.2 = INTEGER: greaterOrEqual(4)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdRelation.10.3 = INTEGER: lessOrEqual(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdRelation.10.4 = INTEGER: lessOrEqual(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdRelation.11.1 = INTEGER: greaterOrEqual(4)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdRelation.11.2 = INTEGER: greaterOrEqual(4)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdRelation.11.3 = INTEGER: lessOrEqual(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdRelation.11.4 = INTEGER: lessOrEqual(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdValue.9.1 = INTEGER: 1048576000
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdValue.9.2 = INTEGER: 1056964608
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdValue.9.3 = INTEGER: 0
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdValue.9.4 = INTEGER: 0
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdValue.10.1 = INTEGER: 1065353216
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdValue.10.2 = INTEGER: 1053609165
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdValue.10.3 = INTEGER: 1077936128
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdValue.10.4 = INTEGER: 1148846080
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdValue.11.1 = INTEGER: 1818584096
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdValue.11.2 = INTEGER: 172384617
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdValue.11.3 = INTEGER: 1073741824
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdValue.11.4 = INTEGER: -1073741824
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdEvaluation.9.1 = INTEGER: false(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdEvaluation.9.2 = INTEGER: false(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdEvaluation.9.3 = INTEGER: true(1)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdEvaluation.9.4 = INTEGER: true(1)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdEvaluation.10.1 = INTEGER: false(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdEvaluation.10.2 = INTEGER: false(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdEvaluation.10.3 = INTEGER: false(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdEvaluation.10.4 = INTEGER: false(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdEvaluation.11.1 = INTEGER: false(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdEvaluation.11.2 = INTEGER: false(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdEvaluation.11.3 = INTEGER: false(2)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdEvaluation.11.4 = INTEGER: true(1)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdNotificationEnable.9.1 = INTEGER: true(1)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdNotificationEnable.9.2 = INTEGER: true(1)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdNotificationEnable.9.3 = INTEGER: true(1)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdNotificationEnable.9.4 = INTEGER: true(1)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdNotificationEnable.10.1 = INTEGER: true(1)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdNotificationEnable.10.2 = INTEGER: true(1)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdNotificationEnable.10.3 = INTEGER: true(1)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdNotificationEnable.10.4 = INTEGER: true(1)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdNotificationEnable.11.1 = INTEGER: true(1)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdNotificationEnable.11.2 = INTEGER: true(1)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdNotificationEnable.11.3 = INTEGER: true(1)
CISCO-ENTITY-SENSOR-MIB::entSensorThresholdNotificationEnable.11.4 = INTEGER: true(1)
Thanks in advance for any assistance.
Colin ***
