Hi all,
I'm still very new to SolarWinds products so bear with me. I created a Universal Device Poller to monitor the power supplies on a Cisco Nexus switch and its FEX'es. Using the information from Using SNMP to Monitor Cisco Nexus 5000|176871 - Cisco Support Community I used the OID 1.3.6.1.4.1.9.9.117.1.1.2.1.2 for this.
After creating the UnDP I assigned two Cisco Nexus 5548 to it and checked the web portal. It gives me the following output:
Cisco Nexus Power Supplies
| NexusPower - Label | NexusPower |
| 22 | On |
| 23 | On |
| 24 | On |
| 470 | On |
| 471 | On |
| 101000022 | On |
| 101000470 | On |
| 101000471 | On |
The values in the right column are actually "2" but I used the enumerate feature to translate these to the string "On". The label refers to the power supply. The last three are for FEX 101 (first three digits). The first 5 rows are for the Nexus 5548.
My question now is: how do I translate the numbers from the first column to meaningful strings? Any help is appreciated.
Thanks in advance!
Tom
