Hi
I am currently trying to poll (using a custom poller) The Cpu Utilisation on a Juniper SA6000 box with little or no success. I have a custom poller monitoring the CPU Util on a Juniper SA 4000 which is accurate. When I downloaded the mib database from the SA6000 I found that the OID for CPU util is the same as the one on the SA4500.
however when I poll it I find that it returns a value of 100 all the time which is incorrect. Are there a number of pollers I need to combine in order to get a correct value for this stat? I have had to do this on some F5 switches, has anyone experienced this with the Juniper S600 before?
Cheers
