Tengo un problema al conectar el servidor del poller principal con el servidor SQL, adjunto imagen
¿Alguien sabe cómo arreglar este problema?
PD: #S.O: Windows server 2012 R2 con reglas en Firewall para los puertos 17777 y 17778
(assuming I can trust Google Translate) Can you manually telnet to these ports on the SolarWinds server from the Additional Polling Engine server?
what about port 80 to the main poller shouldn't that need to be open ?
only if you want to be able to get to the web console from the additional polling engine.
