Hi Everyone,
With the release of 2018.2, APC UPS monitoring is now natively supported. I have been trying to figure out why some of my APC UPS units are reporting correctly, and others are not. I am referring to the Power Control Unit Status section of node details, SNMP is functioning but returned unknown status' for a few fields. While the other fields work as expected. Based on my environment, I have been able to limit the problem to SMARTUPS2 devices (aka UPS Network Management Card 2). Where my other older UPS units, like Smart-UPS 3000 RM XL, work without issue. In the example below, I provided one working and one not working node. The battery does not need replacement on this particular node, but returns wrong.
SMARTUPS2
| UPS STATUS | | Unknown |
| | BATTERY STATUS | | Unknown |
| | NAME | | APC UPS |
| | SERIAL NUMBER | | AS1628264973 |
| | MODEL | | Smart-UPS X 3000 |
| | LAST FAIL CAUSE | | Self Test |
| | BATTERY PACK COUNT | | 0 |
| | OUTPUT LOAD | | 0 % |
| | BATTERY CAPACITY | | 0 % |
| | BATTERY TEMPERATURE | | 32 °F |
| | TIME ON BATTERY | | 0 |
| | RUN TIME REMAINING | | 0 |
| | REPLACE INDICATOR | | Battery Needs Replacement |
| UPS STATUS | | On Line |
| | BATTERY STATUS | | Normal |
| | NAME | | {removed} |
| | SERIAL NUMBER | | JS0801002212 |
| | MODEL | | Smart-UPS 3000 RM XL |
| | BATTERY CAPACITY | | 100 % |
| | BATTERY TEMPERATURE | | 64.4 °F |
| | RUN TIME REMAINING | | 4h:28m:00s |
| | REPLACE INDICATOR | | Battery Doesn't Need Replacement |
Any information or recommendations are appreciated.
