Hello Orion SDK Community,
I've verified through the Metadata.Entity namespace/table that the Orion.APM.Component table is only available through the API to read or invoke - not the ability to delete, create, or update.
I really need this ability through the API to do exactly those operations... delete/create/update.
To that end, I began inspecting web calls through the GUI and found the following operations:
localserver/.../DeleteComponents (For delete operation)
localserver/.../CopyToApplicationTemplate (For create operation)
all referenced in the following file:
C:\inetpub\SolarWinds\Orion\APM\Services\Components.asmx
I was using these services recently with JSON and normal authentication successfully until I recently installed hotfixes during an upgrade to 12.1 -
The account i'm using to make the request has all possible access/permissions enabled and yet I'm getting a 401 unauthorized error as a response:
"Message": "Authentication failed.",
"StackTrace": null,
"ExceptionType": "System.InvalidOperationException"
Credentials are correct, but failing. Other than these methods to delete/create, are there any other options in the API for creating / deleting components? I see an Invoke property is set to true, but no verbs that I'm aware of.
I would really hate to resort to deleting / adding components using SQL - not even sure that would work for the create, but not ideal.
Thank you,
=swql
tdanner / tomas.vrabel
HeHel
