Need help upgrading from Web help desk version 11.0.7 to 12.1
thanks.
Yes you can! In fact I'm doing this in production tonight. Notice I said production right? That's because I tested this out in a stage environment with a backup of our prod db. There are major problems with the db if you're using SQL 05 or 08 that have to be corrected before the upgrade can complete. I opened a ticket with Solarwinds about it but eventually had to provide them with the SQL query needed to fix.
See if this helps:
Web Help Desk (WHD) - Updated January 10, 2014
