Hello,
Props to chad.every for making these great awesome slack integration alert, everyone should definitely have a look at his scripts
Slack Alert Integration - Overview
I am having an issue with one of the scripts though, For some reason, it does not seem to properly send the data over to slack, in particular, the Memory Module
Should like something like (Props to chad.every)
Here is the snippet below of the settings
Here is the snippet of the Alert settings, For some reason it doesn't look like it is not sending the $ORIONTIME? but for all his other scripts, they work excellent, just the "MEMORY POwershel",
I have attached the link of the script https://thwack.solarwinds.com/servlet/JiveServlet/downloadBody/188402-102-4-29570/
Another pair of eyes would be appreciated
Path I used from your snippet
C:\windows\system32\windowspowershell\v1.0\powershell.exe -ExecutionPolicy unrestricted -command "C:\curl\ps\Slack_Alert_Trigger_Action_Node_Memory.ps1 '${N=SwisEntity;M=DisplayName}' '${N=SwisEntity;M=Stats.PercentMemoryUsed}' '${N=SwisEntity;M=MemoryUsed}' '${N=SwisEntity;M=TotalMemory}' '${N=SwisEntity;M=PercentMemoryUsedThreshold.IsLevel1State}' '${N=SwisEntity;M=PercentMemoryUsedThreshold.IsLevel2State}' '${N=Alerting;M=AlertDetailsUrl}' '${N=SwisEntity;M=DetailsUrl}' '${N=Alerting;M=AcknowledgeUrl}' '${N=Generic;M=DateTime;F=OriginalValue}'"
From the powershell script - I Simply downloaded the link provided by your original post - The only area I have modified was the Token and Channel
