I'm learning some SQL on the way to getting more information out of SolarWinds NPM. This query pulls the information together to show the interface name, IP, subnet mask, the caption that's been entered, the description on an interface, what node it's on, what's the interface name, and some comments about the node.
It Pulls from the following SQL tables:
- Interfaces
- NodeIPAddresses
- NodesData
- NodesCustomProperties
I'm a Network Engineer by training - with a little Regex (for looking at IOS and working with BGP) ... and a SQL N00b. I'm sure this query could be prettier, so have pity. I used the "Database Manager" utility on the SolarWinds Orion server itself to find the tables and the data they contained.
Thanks to: Richard Letts for getting me started in the right direction with his helpful link Join Fundamentals
RichardLetts
I also found SQL Tutorial which was helpful allowing me to play with an on-line test database, with examples and explanations.
Here's the SQL Query:
SELECT i.NodeID as "NodeID", i.InterfaceName as "Int Name", i.Caption, i.InterfaceAlias as Description, i.IfName, nip.IPAddress as "IP Address", nip.SubnetMask as "SubnetMask", nd.Caption as "Node Name", ncp.Comments as "Node Comments" From [Interfaces] as i, [NodeIPAddresses] as nip, [NodesData] as nd, [NodesCustomProperties] as ncp where i.NodeID = nip.NodeID and nip.NodeID = nd.NodeID and nd.NodeID = ncp.NodeID and i.InterfaceIndex=nip.InterfaceIndex |
Here's the output, with some redaction:
I hope this helps you - Pseudocyber
