I am having some issues with techs not seeing all of the tickets that are in their queue? But when you search for the tickets you are see them
We have this logged with Support already, I suggest you do the same.
I got an answer - it is because of leveling with the techs. WHD is designed to use the escalation feature not as a "this ticket needs to get taken care of right away" but "level 1 techs cant fix this so we need to escalate it to a level 2 tech". This would then pull the ticket from the level one techs group and now they would not be able to see it
This sounds like a good enough reason to not use this feature. Are you seeing success with the auto escalation?
Yea, faulty logic IMO. I've also logged a support ticket/feature request for it as well.
The best solution is to add the tech(s) to the queue(s) they cannot see.
