Hello,
I am pretty new in Kiwi CatTools so don't expect much.
The switch i wanted to back-up is the Cisco.SmallBusiness SF-300-24PP.
I keep getting this error;
'' Did not receive command prompt after connecting via SSH ''
Hello Bkyle and Jeremy,
Thank you for the information about that error code it is fixed now !
But now i get a other error code: Now i got a error: Did not Receive expected username prompt when entering enable mode
Here are some screen shots of my prompts.
And this is the debug file.
<NEWSESSION CatTools 3.11.2 31-10-2017 9:31:42>
<PROTOCOL=SSH2>
<DEVICE TYPE=Cisco.SmallBusiness>
<ACTIVITY TYPE=Device.Backup.Running Config>
<ACTIVITY SCRIPT=C:\Program Files (x86)\CatTools3\Scripts\Client.Device.Backup.Running Config.txt>
<USERS NAME FOR DEVICE=tes3>
<C OK 9:31:43>
<R-9:31:43>[13][10][13][13][10]Krinkels Automatisering B.V.[13][10][13][13][10][13]SW-NL-BREDA-3[13][10][13][13][10][13][10]SW-NL-BREDA-3#
<W-9:31:43>[13]
<R-9:31:43>[13][10]
<R-9:31:43>[13][13][27][KSW-NL-BREDA-3#
WFMDRetVal=1 Waiting for: "KSW-NL-BREDA-2>"
WFMDRetVal=2 Waiting for: "KSW-NL-BREDA-2#"
WFMDRetVal=3 Waiting for: "KSW-NL-BREDA-2("
WFMDRetVal=4 Waiting for: "(config)"
WFMDBuffer="[13][10][13][13][27][ksw-nl-breda-3#"
<W-9:32:13>enable
<R-9:32:13>e
<R-9:32:14>nable
<W-9:32:14>[13]
<R-9:32:14>[13][10]
<R-9:32:14>[13]% Unrecognized command[13][10]SW-NL-BREDA-3#
WFMDRetVal=1 Waiting for: "KSW-NL-BREDA-2#"
WFMDRetVal=2 Waiting for: "KSW-NL-BREDA-2>"
WFMDRetVal=3 Waiting for: "Password:"
WFMDRetVal=4 Waiting for: "cisco"
WFMDBuffer="[13][10][13]% unrecognized command[13][10]sw-nl-breda-3#"
i have tried everything but i keep getting other errors like if i delete the prompts it gives me a error:
Did not receive expected response to command: show running-config
Did not receive expected prompt after disable command
Maybe you guys have a solution for me thanks !
It looks like the username prompt includes additional information.
So what should i change in the username prompt?
If you log in with putty, what prompts do you see?
Some of the SF and SG cisco switches need to have SSH enabled from the GUI before you perform these steps or in the case of my SF300 you have to generate the RSA certificate. if this has been done, then as stated above attach with Putty and see what you get.
I am having a similar problem with a Cisco Small Business SG300 switch. I"m only about a couple days into an eval so don't know anything about CatTools, but it looks to me like my problem (and perhaps this problem) is being caused by the CatTools script adding a letter K to the beginning of the device name in its stored parameter, so it is looking for a prompt that it never gets...
Here is the text from my debug:
<NEWSESSION CatTools 3.11.3 1/5/2018 3:22:52 PM>
<PROTOCOL=Telnet>
<ACTIVITY SCRIPT=F:\Program Files (x86)\CatTools3\Scripts\Client.Device.Backup.Running Config.txt>
<USERS NAME FOR DEVICE=JerrywSwitch>
<C OK 3:22:52 PM>
<R-3:22:52 PM>[13][10][13]
<R-3:22:52 PM>[13][10]This is the switch in Jerry's office...[13][10][13][10]User Name:
<W-3:22:52 PM>kiwi[13]
<R-3:22:52 PM>kiwi[13][10][13]Password:
<W-3:22:52 PM>Pa55ypassword[13]
<R-3:22:52 PM>*
<R-3:22:53 PM>************[13][10][13][13][10][13][10]JWOffice# <-----------Here is the name of the switch********
<W-3:22:53 PM>[13]
<R-3:22:53 PM>[13][10]
<R-3:22:53 PM>[13][13][27][KJWOffice# <-----------Here is where it looks like it is adding a K and saving it as a stored parameter
<R-3:22:53 PM>[13][10][13][13][27][KJWOffice#
<W-3:22:53 PM>show running-config
<R-3:22:53 PM>show running-config
<R-3:22:53 PM>[13]config-file-header[13][10]JWOffice[13][10]v1.4.0.88 / R800_NIK_1_4_194_194[13][10]CLI v1.0[13][10]set system mode router [13][10][13][10]file SSD indicator encrypted[13][10]@[13][10]ssd-control-start[13][10]ssd config[13][10]ssd file passphrase control unrestricted
<R-3:22:54 PM>[13][10]no ssd file integrity control[13][10]ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0[13][10]![13][10]vlan database
<R-3:22:54 PM>[13][10]vlan 10,65,100[13][10]exit[13][10]voice vlan id 100[13][10]voice vlan state auto-enabled[13][10]voice vlan oui-table add 0001e3 Siemens_AG_phone________[13][10]voice vlan oui-table add 00036b Cisco_phone_____________[13][10]voice vlan oui-table add 00096e Avaya___________________[13][10]
<R-3:22:54 PM>[27][0mMore: <space>, Quit: q or CTRL+Z, One line: <return>
<W-3:22:54 PM>
<R-3:22:54 PM>[13]
<R-3:22:55 PM> [13]voice vlan oui-table add 000fe2 H3C_Aolynk______________[13][10]voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone[13][10]voice vlan oui-table add 00d01e Pingtel_phone___________[13][10]voice vlan oui-table add 00e075 Polycom/Veritel_phone___[13][10]voice vlan oui-table add 00e0bb 3Com_phone______________[13][10]no eee enable[13][10]bonjour interface range vlan 1
<R-3:22:55 PM>[13][10]hostname JWOffice[13][10]
<R-3:22:55 PM>no passwords complexity enable[13][10]passwords aging 0[13][10]username kiwi password encrypted cdd4a0d91c118f4200cdbabefb6f34cd5ba9df3e privilege 15[13][10]username cisco password encrypted cf41645b4df31e9472d0f53a988c840d2a019435 privilege 15[13][10]ip ssh server[13][10]ip ssh password-auth[13][10]snmp-server server[13][10]snmp-server location "Jerry's Office - Admin"[13][10]snmp-server contact "Jerry Weygint (520)975-1936"
<R-3:22:55 PM>[13][10]snmp-server community public ro view Default[13][10]
<R-3:22:55 PM>clock timezone " " 0 minutes 0[13][10]ip telnet server[13][10]
<R-3:22:56 PM>![13][10]interface vlan 1[13][10][27][0mMore: <space>, Quit: q or CTRL+Z, One line: <return>
<W-3:22:56 PM>
<R-3:22:56 PM>[13]
<R-3:22:56 PM> [13] ip address 10.10.0.166 255.255.0.0[13][10] no ip address dhcp[13][10]!
<R-3:22:56 PM>[13][10]interface vlan 65[13][10] name "Fastlink A"[13][10]![13][10]interface vlan 100[13][10] name voice[13][10]![13][10]
<R-3:22:57 PM>interface gigabitethernet1[13][10] no eee enable[13][10]
<R-3:22:57 PM> gvrp vlan-creation-forbid[13][10] gvrp registration-forbid[13][10]
<R-3:22:57 PM> no eee lldp enable[13][10]!
<R-3:22:58 PM>[13][10]interface gigabitethernet2[13][10] no eee enable[13][10] gvrp vlan-creation-forbid[13][10] gvrp registration-forbid[13][10]
<R-3:22:58 PM> no eee lldp enable[13][10]![13][10]interface gigabitethernet3[13][10][27][0mMore: <space>, Quit: q or CTRL+Z, One line: <return>
<W-3:22:58 PM>
<R-3:22:58 PM>[13]
<R-3:22:58 PM> [13] no eee enable[13][10] gvrp vlan-creation-forbid[13][10] gvrp registration-forbid[13][10] no eee lldp enable[13][10]![13][10]interface gigabitethernet4[13][10] no eee enable[13][10] gvrp vlan-creation-forbid
<R-3:22:58 PM>[13][10] gvrp registration-forbid[13][10] no eee lldp enable[13][10]![13][10]interface gigabitethernet5[13][10] no eee enable[13][10] gvrp vlan-creation-forbid[13][10] gvrp registration-forbid[13][10]
<R-3:22:59 PM> no eee lldp enable[13][10]![13][10]interface gigabitethernet6[13][10] no eee enable[13][10] gvrp vlan-creation-forbid[13][10] gvrp registration-forbid[13][10] no eee lldp enable[13][10][27][0mMore: <space>, Quit: q or CTRL+Z, One line: <return>
<W-3:22:59 PM>
<R-3:22:59 PM>[13]
<R-3:22:59 PM> [13]![13][10]interface gigabitethernet7[13][10] no eee enable[13][10] gvrp vlan-creation-forbid[13][10] gvrp registration-forbid[13][10] no eee lldp enable[13][10] power inline never[13][10]!
<R-3:22:59 PM>[13][10]interface gigabitethernet8[13][10] no eee enable[13][10] gvrp vlan-creation-forbid[13][10] gvrp registration-forbid[13][10] rate-limit 25000 35000[13][10] traffic-shape 35000 50000
<R-3:22:59 PM>[13][10] switchport mode access[13][10] switchport access vlan 65[13][10] no eee lldp enable[13][10]![13][10]interface gigabitethernet9[13][10] no eee enable[13][10] gvrp vlan-creation-forbid
<R-3:23:00 PM>[13][10] gvrp registration-forbid[13][10][27][0mMore: <space>, Quit: q or CTRL+Z, One line: <return>
<W-3:23:00 PM>
<R-3:23:00 PM>[13]
<R-3:23:00 PM> [13] switchport mode access[13][10] switchport access vlan 65[13][10] no eee lldp enable[13][10] !next command is internal.[13][10] macro auto smartport dynamic_type unknown[13][10]![13][10]interface gigabitethernet10[13][10] no eee enable[13][10]
<R-3:23:00 PM> gvrp vlan-creation-forbid[13][10] gvrp registration-forbid[13][10] switchport trunk allowed vlan add 10,65,100[13][10] no eee lldp enable[13][10]!
<R-3:23:01 PM>exit[13][10]banner login ^C[13][10]This is the switch in Jerry's office...[13][10]^C[13][10]macro auto disabled[13][10]no macro auto processing cdp
<R-3:23:01 PM>[13][10]no macro auto processing lldp[13][10]macro auto processing type ip_phone disabled[13][10]macro auto processing type ip_phone_desktop disabled[13][10][27][0mMore: <space>, Quit: q or CTRL+Z, One line: <return>
<W-3:23:01 PM>
<R-3:23:01 PM>[13]
<R-3:23:01 PM> [13]macro auto processing type switch disabled[13][10]macro auto processing type ap disabled[13][10]ip default-gateway 10.10.0.1
<R-3:23:02 PM>[13][10]
<R-3:23:02 PM>JWOffice#
WFMDRetVal=1 Waiting for: "More:"
WFMDRetVal=2 Waiting for: "% Unrecognized command"
WFMDRetVal=3 Waiting for: "% Incomplete command"
WFMDRetVal=4 Waiting for: "Yes/press any key for no"
WFMDRetVal=18 Waiting for: "[27][KJWOffice>"
WFMDRetVal=19 Waiting for: "[27][KJWOffice#" <--------------Here is where it is waiting for the prompt with a K in it that it will never see
WFMDRetVal=20 Waiting for: "[27][KJWOffice("
WFMDBuffer="[13] [13]macro auto processing type switch disabled[13][10]macro auto processing type ap disabled[13][10]ip default-gateway 10.10.0.1[13][10]jwoffice#"
<W-3:25:32 PM>[13]
<R-3:25:32 PM>[13][10]
<R-3:25:32 PM>[13][13][27][KJWOffice#
<R-3:25:33 PM>[13][13][27][KJWOffice#
<W-3:25:33 PM>disable
<R-3:25:33 PM>d
<R-3:25:33 PM>isable
<W-3:25:33 PM>[13]
<R-3:25:33 PM>[13][10]
<R-3:25:33 PM>[13]JWOffice>
WFMDRetVal=1 Waiting for: "[27][KJWOffice>"
WFMDRetVal=2 Waiting for: "[27][KJWOffice#"
WFMDBuffer="[13][10][13]jwoffice>"
<W-3:26:03 PM>[13]
<R-3:26:03 PM>[13][10]
<R-3:26:04 PM>[13][13][27][KJWOffice>
<W-3:26:04 PM>exit[13]
<D 3:26:04 PM>
<SCRIPT VALUES>
<HOSTNAME=" [KJWOffice">
<PROMPT VTY=" [KJWOffice>">
<PROMPT ENABLE=" [KJWOffice#">
<PROMPT CONFIG=" [KJWOffice(">
