I am trying to create a way for users to be able to bulk mute servers in a group. I ended up creating dynamic group queries to look for servers belonging to certain node custom properties. I then created a custom view to list (linkable) nodes belonging a root group. Users can now select the group and edit the group custom property group called mute_group, and set to mute.
Now I need to create an advanced alert to lookup the group field if it's set to "mute_group", and at the same time, also look for other node.custom property variables.
However when I try to create an advanced alert, I can't link to the group custom property to any node details.
So, I am thinking of creating an advanced swql alert, however when I try to create this in swql it's giving an ambigous error.
Is there a way to link both the orion.groups and orion.nodes together by swql in the advanced swql alerting?
Thanks in advance!
