Hello All,
I'm trying to do a http post to create a container and I can't seem to get the syntax right.
I've tried almost every possible combination for the memberDefinition section and nothing seems to work...
URL:
localhost:17778/.../CreateContainer
POST DATA:
{"name":"Orion123","owner":"Core","frequency":60,"statusCalculator":0,"description":"testing container creation","pollingEnabled":"true","memberDefinitions":[<ArrayOfMemberDefinitionInfo xmlns:i="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://schemas.solarwinds.com/2008/Orion"><MemberDefinitionInfo><Name>Testy123</Name><Definition>filter:/Orion.Nodes[CustomProperties.IT_Service='WAN' AND CustomProperties.Site_Code='USA']</Definition></MemberDefinitionInfo></ArrayOfMemberDefinitionInfo>]}
from SWQL Studio if I populate the values through the Invoke function (right click on the CreateContainer option) I have no issue, so I'm assuming there must be some error with my JSON formatting.
The above example is using the following format:
"memberDefinitions":[%data%]
I've also tried using another example found on thwack as well:
{"name":"Orion123","owner":"Core","frequency":"60","statusCalculator":"0","description":"hello","pollingEnabled":"true","memberDefinitions":["name":"Test1234","definition":"filter:/Orion.Nodes[CustomProperties.IT_Service='WAN' AND CustomProperties.Site_Code='USA']"]}
If anyone can assist with this, it would be greatly appreciated... trying to automate container creation, and hopefully group dependencies after -
Help me DTANNER AND THWACK COMMUNITY, you're my only hope
