I need to have a link from Orion to Virtualization Manager.
Does it provide this, something like with Storage Manager?
No currently - although Virtualization Manager widgets can be embedded in the Orion dashboards - that is documented here http://thwack.solarwinds.com/community/solarwinds-community/product-blog/blog/2011/08/29/single-pane-of-glass-tying-in-storage-manager-virtualization-manager-into-orion-dashboard
Jon
Jon,
The document you referenced shows using a URL WIDGET, however this does not appear in the Virtualization Manager I have installed. I've looked in several areas for this, but no luck so far.
Could it be found elsewhere within the product or perhaps that feature was dropped in this release (4.1) ?
Thanks.
To obtain in URL to a widget click on the "Copy widget link" option under the widget options:
