So - I am fine tuning the virtual environment in Orion - I got the Integrated Virtual Infrastructure Monitor V1.10.0 when I updated (either) NPN or APM.
When I customize the page with Assets, Summary, all looks good, but if I try to add Datastore IOPS, VM Latency, Virtualizaiton Storage Summary - I get the following dialogue:
This resource relies on data from the Virtualization Manager product. if you already have VMan installed in your environment, you need to tell Orion.
Do I need a patch / update - or do I need to purchase the full blown install?
If you all tell me to click on "Integrate Virtualization Manager" - what server do I use? I have all components loaded on a single VM - running the Orion Suite.
