We are a school and we want to print out bar coded asset tags to affix to our student laptops. Can we do this from WHD? Anyone have any suggestions? Thanks
If you're interested in actual security labels that are hard to remove and leave a "VOID" label when they are removed, I recommend Maverick Labels. Otherwise, if security labels are not really your thing, Dymo makes labelmakers and provides software for creating your own barcodes. In my shop, the security barcode matches the Asset Number in WHD. WHD will not "generate" labels for you, but you can get labels to match the numbers in WHD.
OK. So WHD won't do it. I would need to use another piece of software like
Dymo's or Brother's p Touch?
Thanks for the help.
Regards,
Kim Young
MS laptop technician
Packer Collegiate Institute
170 Joralemon Street
Brooklyn, NY 11201
(718) 250-0217
On Fri, Sep 11, 2015 at 8:31 AM, <
That is correct. WHD will not generate the actually barcodes.
