eI recently installed Enterprise Operations Console 1.4.1 concurrently on a server hosting NPM 10.4 and NTA 3.10.
It is working as expected, except for gathering information from the NPM/NTA instance installed on the same server. In that case, the polling/processing gets stuck at 75%. It is showing the number of interfaces in that NPM instance, but not the number of nodes.
I am not seeing any errors in any server event logs that would show why this is failing. Also, utilization on the server is less than 50% on both memory and cpu, and disk I/O has not increased noticeably since installation of EOC. I saw a notice about EOC 1.3 and NPM 10.3 not being compatible when using IIS6. Is that still the case and should I follow the steps to resolve that?
Any suggestions would be greatly appreciated.
Thanks!
