I am having a problem with UDT where I do not believe it is showing me all of the data it should. I am not seeing any endpoints when looking to see where a workstation is hooked up to. I do not see any direct connection types nor do I see any layer 2 connections. I am dealing primarily with Cisco 3700 series and 6500 series switches. I am running SNMPv3 on all of the devices and have no problem monitoring any of the devices with NPM. I ran the UDT compatability checker against one of the devices and it shows an authorization error for several OIDs and fails those checks. If I do a SNMP walk on the device the OID it looks for does not show up but does not tell me I don't have rights. Attached is the result of the compatability check..
Any thoughts?
