I am the administrator on a Microsoft Windows Server 2003 Standard (32-bit) - GSNAPRINT installed with IPmonitor tool version 9. I want to add an drive space alert for another server (Windows Server 2008 R2 - Standard - GSCTTLBACKUP) but was not successful.
But there were other file shares which were added for monitoring on IPmonitor to the same server (GSCTTLBACKUP).
I have attached the screenshot for reference. After I log on the GSNAPRINT server web console and I click on "Return to Device View" where I am not finding the second option.
I am following this link https://support.ipmonitor.com/helps/649580d2e53d4207813667c9a7db0f12.aspx for configuring, but I am not able to find the second step as mentioned below.
2. Click the Monitors menu option, then select Add a Monitor.
SNMP services are enabled on GSCTTLBACKUP server. Ping alert is working for the same server.
Kindly help me!
