Hello.
If i click on an imprted Assets like a Computer or Laptop, i see Custom Field option, with no Custom Fields. I looked around, but havent found anywhere, where i can define and link them to my Asset. Do you have an Idea?
Whether you're managing digital files, equipment, inventory, or IT resources, custom fields allow you to capture data that is specific to Random item Generator your organization's needs, such as warranty expiration dates, purchase costs, assigned departments, serial numbers, maintenance schedules, or compliance status.
You create the custom field in "Custom Fields" under "Service Desk" in Setup. Then, in Custom Forms, you select "Computers" or whatever asset you wanted the custom fields to appear under. Edit the form and add the fields you want to appear in the custom fields section on the asset.
You would need to apply fields via dynamic form rules - https://www.youtube.com/watch?v=bFBx9uP8hcU
