i cant add omada wireless control in Solarwinds . how to add it ?
Hello @jamilhussain
By default Omada is not under the list of supported vendors, check the below link which lists all the vendors that are supported.
Network infrastructure support by vendor
But by stating that it doesn't mean SolarWinds cant do anything about it, you should probably try Manage Pollers and/or UnDP (Universal Device Poller), by using this, you should be able to pull in base monitoring statistics for omada via SNMP. Check the below links on how to create them
Create pollers in Device Studio for NPM
How to Create a Universal Device Poller (UnDP) in NPM
Assign Universal Device Pollers to devices monitored
Hope this helps.
