Hi All,
NPM version 2025.4.0
C9800-L-F IOS-XE version 17.15.03
Managed APs CW9176I
We've recently replaced WLC from Cisco 5520 to Cisco C9800-L-F, and tried to update the Solarwinds Wireless Heat Map.
In the previous WLC model, I was able to add managed APs to the heat map showing their locations etc, however, with the new WLC I'm not able to do so.
WLC is managed with snmp v3 and when I go to Dashboards >Network > Wireless, I can see all the managed APs. Tried to "manage as node" using the same snmpv3 setting for managing the WLC, but test fails for authentication and unable to add them. This is somewhat expected as these APs are meant to be "light weight" and should be managed from WLC.
I saw some thwack post saying to right click the WLC and select "Show related entities", but this just shows physical modules installed and not showing any managed APs.
Also saw another post to enable OIDs Wireless OIDs polled in NPM
While not enabled, we can see some info already and not sure if this would help?
How do I go about adding the APs to the map so that we know which AP is located where etc and better manage them going forward?
Many thanks.
