The other day I was having a conversation with someone new to IT (They had chosen to pursue down the programming track of IT which can be an arduous path for the uninitiated!). The topic of how teaching, education and learning to program came up and I’d like to share this analogy which not only works out with programming but also I’ve found pretty relevant to all aspects of an IT Management ecosystem.
The act of programming like any process driven methodology is an iterative series of steps, one where you will learn tasks one day which may ultimately remain relevant to future tasks. And then there are tasks you’ll need to perform which are not only absolutely nothing like you did the previous day, they’re unlike anything you’ve ever seen or imagined in your whole career, whether just starting out or you’ve been banging at the keys all your life. The analogy I chose for this was cooking, I know I know, the relevance hopefully should resonate with you!
When you get started out cooking, correct me if I’m wrong but you’re usually not expected to prepare a perfectly rising without falling soufflé, No, not at all. That would be a poor teaching practice and one where you’re setting up someone for failure. Instead, let’s start out somewhere simple, like Boiling water. You can mess up boiling water but once you start to understand the basic premise of it you can use it for all kinds of applications! Sterilizing water, cooking pasta or potatoes, the sky is the limit! Chances are, once you learn how to boil water you’re not going to forget how to do it and perhaps will get even better at doing it, or find even more applications. The same is true systematically that once you start navigating into PowerShell, Bash, Python or basic batch scripts; what you did once you’ll continue to do over and over again because you understand it, but more so you got it down pat!
The day will come however you’re asked to do something you didn’t even think about the day prior, no more are you asked to perform a basic PowerShell script to dump the users last login you could whip up before in a single line of code (boiling water) and instead you’re asked to parse in an XLS or CSV file to go make a series of iterative changes throughout your Active Directory (Or for practical use-case sake, Query active directory for workstations which haven’t logged into AD or authenticated in the past 60 days, dump that into a CSV file, compare them against a defined whitelist you have in a separate CSV, as well as omitting specific OUs and then perform a mass ‘disable’ of those computer accounts while also moving them into a temporarily ‘Purge in 30 days’ OU and generate a report to review.) Oh we also want this script to run daily, but it can’t have any errors or impact any production machines which don’t meet these criteria. Let’s for the sake of argument… Call this our soufflé…
Needless to say, that’s a pretty massive undertaking for anyone who was great at scripting, scripting that which they’ve been doing a million times before. That is what is great about IT and cooking though. Everything is possible, so long as you have the right ingredients and a recipe you can work off of. In the given above scenario performing every one of those steps all at once might seem like the moon to you, but you may find that if you can break it down into a series of steps (recipe) and you’re able to perform each of those individually, you’ll find it is much more consumable to solve the bigger problem and tie it all together.
What is great about our IT as a community is just that, we are a community of others who have either done other things before, or perhaps have done portions of other things before and are often willing to share. Double-down this to the fact that we’re also a sharing is caring kind of community who will often share our answers to complex problems, or work actively to help solve a particular problem. I’m actually really proud to be a part of IT and how well we want each other to succeed while we continually fight the same problems irrespective of size of organization or where in the world.
I’m sure for every single one of us who has a kitchen we may have a cookbook or two on shelves with recipes and ‘answers’ to that inevitable question of how we go about making certain foods or meals. What are some of your recipes you’ve discovered or solved over the time of your careers to help bring about success. I personally always enjoyed taking complex scripts for managing VMware and converting them into ‘one-liners’ which were easy to understand and manipulate, both as a way for others to learn how to shift and change them, but also so I could run reports which were VERY specific to my needs at the moment while managing hundreds and thousands of datacenters.
I’d love it if you’d share some of your own personal stories, recipes or solutions and whether this analogy has been helpful if not explaining perhaps what we do in IT to our family who may not understand, but maybe in cracking the code on your next Systems Management or process challenge!
