If you already have anomaly-based alert definitions created, it is difficult to see which nodes are selected as a part of the condition. This is especially so if you have thousands of nodes in your environment.
When you create an anomaly-based alert, you have to select which nodes are a part of each alert definition one by one. The only filter options are status and type, and the only sort options are name, status and type. So, if you want to see all of the nodes selected in the condition, you have to scroll through every page of nodes to see which ones are selected. There is no place to see all of these nodes in one place.
If you try to edit the alert in the legacy alert management page, it is setup as a canned alert. So, the entity selector in the condition is greyed out and you can't see them there either.
It would be helpful to quickly see/select/edit which nodes are a part of the conditions for these alerts without having to scroll through the endless pages of nodes in the entity selection page.
