The current NPM/Orion version still does not have a field for Admin Status for Routing Neighbor, which can be extremely useful for alerting (reducing alert noise; there is no differentiation possible between peers that are set to 'Admin Down' and those who are not). The value for this is stored here:
 | Specific Object Information |  |
| Object | bgpPeerAdminStatus | | OID | 1.3.6.1.2.1.15.3.1.3 | | Type | INTEGER | | Permission | read-write | | Status | current | | Values | 1 : stop 2 : start
| | MIB | BGP4-MIB ; - View Supporting Images  | | Description | "The desired state of the BGP connection. A transition from 'stop' to 'start' will cause the BGP Start Event to be generated. A transition from 'start' to 'stop' will cause the BGP Stop Event to be generated. This parameter can be used to restart BGP peer connections. Care should be used in providing write access to this object without adequate authentication." |
A value of '1' means that the peer is administratively down.
The current means to get around this limitation is to create a UnDP for the OID above and create a custom SQL/SWQL alert (when alerting on Routing Neighbors you cannot use custom pollers in conjuction with this type of object).
