I've found great use in the left hand navigation screens. Not so much for the NOC, but for myself and other application owners. The screens tend to get crowded, and it sure would be nice to use left hand navigation without every tab inheriting the view limitation of the top tab. Can you code it to where each left hand tab can have its own view limitation? That way, if a person had many applications that they were responsible for, you could separate it that way. Also, the fact that the tabs inherit view limitations makes it difficult when you're trying to create multiple application detail or component details attributed to different servers. There's a list of report options for each, but what I may want to use is only in report type A instead of report type B.
Thanks!
Dave Burton
