Is there a way to archive assets with an e-waste and/or decommissioned status?
You can create your own Asset Status entries and set any given asset to that status. It's not an archive per se as it will still be there and query-able, but you can create whatever different Asset Status things you want.
Thanks. I did create e-waste and decommissioned status's just didn't want them to display on a regular search.
You can do a Search for "Status" "is any of" and then select only those 'statuses' you want. You can eliminate the "e-waste" by not selecting it.
