Hi All SolarWinds Gurus,
I am stuck at trying to find out how to create a rule which would include "NOW" variable. Basically I have a Custom Field defined as DATE type and I need to check whether date is in the past or in the future. For me to be able to do this I simply need to do something like:
Trigger alert when "Custom_Date" is less than "Now"
any thoughts on how to achieve this?
P.S.
If you select "Polling Engines" as Type of Property to Monitor you will then be able to create some rules which would include "Now" variable (see below). But those are kind of hard coded formulas already, whereas I am looking for just "Now" on its own to be able to compare it to my custom field value
