I am building a SWQL query to grab MAC address and SerialNumber from MikroTik devices. We have it mostly working, but I am struggling getting the query to properly pull the SerialNumber from the Universal Device Poller we have set up.
Normally, I would simply grab the ServiceTag from the database, but these devices do not provide that information directly via SNMP monitoring (thus our use of the UnDP).
The UnDP we have setup is working as intended and shows the data we need, but none of the queries I have attempted will show the actual data. The column always produces a NULL value for the devices.
- The UnDP is using the following OID: 1.3.6.1.4.1.14988.1.1.7.3
- The name is mtxrSerialNumber
- The MIB Value Type is "Raw Value" and the format is "Text"
Here is the most recent query I have attempted:
SELECT
n.NodeID,
n.Caption AS NodeName,
n.IP_Address,
n.Vendor,
n.MachineType,
ncm.SysDescr AS OS_Description,
n.DetailsUrl,
i.MAC AS MACAddress,
mxtr.SerialNumber
FROM Orion.Nodes n
-- Get TOP 1 MAC from Interfaces
LEFT JOIN (
SELECT NodeID, MAC
FROM Orion.NPM.Interfaces i1
WHERE MAC IS NOT NULL
AND InterfaceID = (
SELECT TOP 1 InterfaceID
FROM Orion.NPM.Interfaces i2
WHERE i2.NodeID = i1.NodeID
AND i2.MAC IS NOT NULL
ORDER BY InterfaceID
) i ON i.NodeID = n.NodeID
-- NCM SysDescr
LEFT JOIN NCM.Nodes ncm ON ncm.CoreNodeID = n.NodeID
-- Custom Poller (mxtrSerialNumber) using MAX(RawStatus)
LEFT JOIN (
SELECT
ca.NodeID,
MAX(cs.RawStatus) AS SerialNumber
FROM Orion.NPM.CustomPollerAssignment ca
JOIN Orion.NPM.CustomPollers cp2
ON cp2.CustomPollerID = ca.CustomPollerID
JOIN Orion.NPM.CustomPollerStatistics cs
ON cs.CustomPollerAssignmentID = ca.CustomPollerAssignmentID
WHERE cp2.UniqueName = 'mxtrSerialNumber'
GROUP BY ca.NodeID
) mxtr ON mxtr.NodeID = n.NodeID
WHERE n.Vendor = 'MikroTik'
Any help is appreciated!
