Hi Can DRE and DRS agents run to same computer simultaneously? When I install the DRE agent on the PC where the DRS agent (On-premises) is installed, the service does not start.
Is there a way to run on-premise and Cloud agents together?
Just for edification, why would you not just move to DRE? Is there a strategic reason to have both? Obviously, they are different platforms and operate differently. You might find it better to migrate to a single solution or add additional tools if this solution doesn't work. I love SolarWinds but i am not going to lie on the sword when there are other options.
Hi @ismail.cil
I tried installing the DRS service on a device that has DRE, and both of them are working.
Did you install the DRS first before the DRE?
