Guide on easy steps to set up APC on UPS - 1 - Detect when running on battery or commercial power. Please help.
I would say you'd need to use a custom poller. Work out which oid has the info you're looking for and then create a poller for it.
Thank you I will give that a try.
Try using SmartUPS UNDP. It has most of the required OIDs for APC
https://thwack.solarwinds.com/content-exchange/network-performance-monitor/m/universal-device-pollers/248
Once applied you can show them on your dashboard as required.
Best Regards
AK
