I need to monitor the volumes, CPU and memory, and in case they are greater than a specific percentage, they will be in critical status or warning status and the color of their icon will be converted to
red or yellow color as shown
Hi Reham,,,
It is very simple, Just create a report with all these items as shown, and select caption which is node name and assign Add display settings Status Icon (Watermark)
then you can adjust percentage for warning and critical from ( orion setting - Orion General Thresholds )
I hope this will be helpful
Thank you for replying .I need to display that as view not as report to monitor that table .
You can use the Widget Custom table
thank you
