Running 2020.2.4, noticed the out of the box Cluster predicted memory depletion alert was on.
Before customising it to inform people, I looked at the details and it is displaying the incorrect host as the cause in both the active alert and the event raised.
When I check the query adding in the inner join in to the swql to show the expected host, and also in the alert to try there also, the swql shows as expected but the alert/event still refer to an incorrect host:
SELECT Clusters.Uri, Clusters.DisplayName, hosts.hostname, clusters.MemoryUtilizationDepletionDate FROM Orion.VIM.Clusters AS Clusters
inner join orion.vim.Hosts as hosts on hosts.ClusterID = clusters.clusterid
where DayDiff(getdate(), clusters.MemoryUtilizationDepletionDate)<7
Helpful advice would be gratefully received.
