I bought UDT to help me learn more about my switches, including how many ports are available to use, versus how many are not available (already in use).
Condition: UDT reports a switch as having zero available reports.
Problem: When I SSH into that switch and issue the command "show int status | in not", I see five or ten ports "notconnected." That means they're available to be used.
Double-check: I build a custom report to show which ports have no link, and how long they've been without link (see my instructions for this here: How to create a report displaying the Last Time Data was Transmitted or Received on a Switch Port ). The report confirms what the SSH command shows--that some ports have been down (available) twenty days.
So where is UDT failing to report the available ports?
Is there some threshold in UDT that says to call a port "unavailable" until it has been down at least X number of days?
UDT appears to be discovering/monitoring all the ports in the switch.
Where have I gone wrong installing or configuring UDT?
