Hi folks.
I'm new to Solar winds. I've studied the Orion software.
I'm tasked with creating a visual map of the medium-sized enterprise. What is the best way to do this?
Thank you!
Use Orion Maps.
Here are page to help you get started www.solarwinds.com/.../orion-maps
Thank you for your reply. That helps, but what about devices that have no sensors on them? Will the "sonar" feature work for my needs?
Also, please note the map in the below video. Isn't there a feature that sends out signals in all directions, similar to Nmap, that will create a map of the enterprise? What about the "sonar" feature? Thank you!
youtu.be/JggmX4PVVsg
