Does Orion 2022.3 need upgrading to 2023.1 to mitigate SolarWinds Platform Deserialization of Untrusted Data Vulnerability (CVE-2023-23836)?
Today there is no hotfix for older versions you need to install 2023.1. I have seen articles mention that a patch for older versions may release, but I honestly have not seen that from SolarWinds. Today you should plan to move to 2023.1. Tomorrow? Look at: https://customerportal.solarwinds.com/downloads and see if anything is there.
Thanks JM, the best plan cheers...
It's disappointing there is not a hotfix available yet for older versions that are still under support.I tried using the Product Upgrade Advisor to plan for an upgrade to 2023.1 and it wasn't listed. The latest version listed in upgrade advisor for SAM is 2020.2.6
Same, we want the security fixes, but not the bugs in 2023.1 where a non-admin user using perfstack can cause a system issue.
