SWQL- Need to create total access point status (KPI Widget) ...Please help
  • The data is located in these tables
    Here is an example query for Thin AP Status
    SELECT TOP 10 DisplayName, IPAddress, Clients, Status
    ,CASE WHEN Status = 1 THEN '/Orion/images/StatusIcons/Small-Up.gif'
          WHEN Status = 2 THEN '/Orion/images/StatusIcons/Small-Down.gif'
          WHEN Status = 3 THEN '/Orion/images/StatusIcons/Small-Warning.gif'
          WHEN Status = 9 THEN '/Orion/images/StatusIcons/Small-Unmanaged.gif'
          WHEN Status = 14 THEN '/Orion/images/StatusIcons/Small-Critical.gif'
          ELSE '/Orion/images/StatusIcons/Small-Unknown.gif'
          END AS [IconStatus]
    FROM Orion.Wireless.AccessPoints.Thin
    You may want to take out the TOP 10 or put a WHERE in it but that should get you started. There are several other fields available in those tables.
  • Here is the query for a KPI widget to show total number of AP's up/down.
    Here is the UP widget, change the Status to 2 for a Down Widget, 3 for Warning, etc
    Here is a nice guide:
    A Step-by-Step Guide to Building Modern Dashboards on the Orion® Platform – SolarWinds Lab Episode #93
    SELECT COUNT (Status) as APStatus
    Where STATUS = 1
    Order by COUNT (Status) DESC
