Hi guys
Any know please how to change the statistic data value obtain via an SNMP OID monitor to convert the four digit value to have a decimal point in the middle to represnt the actual temp correctly, so for example I'm getting a reading of 2354 which is real terms is 23.54 degrees c but I'm looking for a way to get the correct value convert otherwise it's confusing for others to read correctly but also the charting and dials are somewhat messed up too!
Settings on the template are
None of the convert values look relevant but someone may know something I dont - if so please enlighten me
