SAM Template shows that it is assigned to x number of Nodes in the "Application Monitor Templates" tab. I click on the link for the x number of Nodes to see which nodes have the template assigned. All of the nodes show up here correctly. I click on the "Assigned Application Monitors" tab, the nodes are nowhere to be found, even if I filter by template name. I can go to the Node itself and see the template is applied and has an "Unknown" status.
Templates are assigned but there is apparently no way to delete them without it showing up in the "Assigned Application Monitors" tab. Is there another way?? I have several nodes with templates assigned in an Unknown status that I cannot clean up.
