We've been building out all sorts of application monitor temlates and it turns out most only have a single component in them.
We didn't think this was a big deal until now:
"SAM Application Polling Rate: 126% of its maximum rate. Polling intervals incrase if the polling rate exceeds 100% of the maximum rate"
As we work to fix the issue, we had the idea, "What if we combine similar components into a single application monitor template and then had a single application with 5 components poll every 5 minutes? Is that better than 5 applications with one component as far as over-taxing the polling engine?"
We planned on combining like components into a like application monitor templates over the next few months, however, if it will help out the situation with the polling engine, then we can speed up that project.
Thanks~!
