Hi Everyone,
I'm new here. Can you help me how to add sql agent job status to a customize page or in NOC view mode?
Hi ryanjay15 ,
unfortunately, there is no out-of-the-box widget that you can use to get this information. You can add a custom query widget to your summary page and paste the below query into it should get you what you need on a summary page
SELECT n.Caption as [Node], app.Name as [Job Name], app.LastRunDate, app.LastRunDuration, app.JobStatusFROM Orion.APM.SqlJobInfoAlert appJOIN Orion.Nodes n on n.nodeid = app.nodeid
Here's a screenshot of it
Let me know how that works for ya
EDIT 1
Did some more tinkering with it and developed a better-looking widget.
SELECT DISTINCT n.Caption as [Node], app.Name as [Name], concat(app.LastRunDuration, 's') as [Last Run Duration], app.JobStatus as [Job Status], case when app.JobStatus = 'Up' then '/Orion/APM/SqlBlackBox/Images/StatusIcons/job_succeeded.png' Else '/Orion/APM/SqlBlackBox/Images/StatusIcons/job_failed.png' end as [_Iconfor_Job Status], n.DetailsUrl as [_LinkFor_Node], sql.DetailsUrl as [_linkfor_Name]FROM Orion.APM.SqlJobInfoAlert appJOIN Orion.Nodes n on n.nodeid = app.nodeidjoin Orion.apm.SqlJobInfo sql on app.ApplicationID = sql.ApplicationIDORDER BY app.Jobstatus
Screenshot
Thank you for your response. I'll try what you suggested and get back to
you as soon as possible.
On Sat, Mar 30, 2019, 1:16 AM christopher.t.jones123 <
This worked great, thanks
Thank you, it works. It would be great to make search working as well.
It's fairly simple to create the search query, it's essentially a copy of the above widget with a "WHERE" statement in there. Below is the search query where you can search based off of node caption
SELECT DISTINCT n.Caption as [Node] , app.Name as [Name] , concat(app.LastRunDuration, 's') as [Last Run Duration] , app.JobStatus as [Job Status] , case when app.JobStatus = 'Up' then '/Orion/APM/SqlBlackBox/Images/StatusIcons/job_succeeded.png' Else '/Orion/APM/SqlBlackBox/Images/StatusIcons/job_failed.png' end as [_Iconfor_Job Status] , n.DetailsUrl as [_LinkFor_Node] , sql.DetailsUrl as [_linkfor_Name] FROM Orion.APM.SqlJobInfoAlert app JOIN Orion.Nodes n on n.nodeid = app.nodeid join Orion.apm.SqlJobInfo sql on app.ApplicationID = sql.ApplicationID where n.caption = '%${SEARCH_STRING}%'ORDER BY app.Jobstatus
is it working for you? for some reason it is not searching, or I may have missed something.
I modified it, try it now. I dont have an environment to validate it with currently, but that syntax should be valid
