I'm trying to get some WMI process monitors working on an BES v4 server, whose database is hosted by a 2nd server.
The component I'm trying to get to work, is part of a larger template that has Windows Service monitoring working fine, but ANY of the Process Monitors do not and, give the same error.
When I test the component, Messages Queued for Delivery, it comes back as "the specified object is not found on the system"
I see there is a field for 'Instance', which has a an asterisk '* in the component template. I assume wildcard and it should just work.
I have tried entering the instance name along in that field without success, but don't know what the correct syntax would be to include the node name and instance name, or if this is the wrong approach.
I'm thinking I need to run these Process monitors like, 'Messages Queued for Delivery', from the actual database server and entering in the instance name in the instance field?
