Is there a way to achieve this?
If only i enter the snmp community and the Ip of the Firewall and it will first get the segments/subnets behind the firewall and then scan these subnets?
Regards
Select the subnet from the Manage Subnet page, and click edit (pencil icon). Scroll down and un-check the box that says "Disable Neighbor Scanning". When you do this, an option to enter a router will appear. Put in the firewall address and make sure the SNMP community string is (IPAM Settings -> SNMP Credentials).
You can try adding the firewall as a neighbor device for the subnet, but your results will vary depending on what firewall you are using.
Thanks but i cannot find a menu to add a neighbor device?
