Hi
I want script to get and update software installed on Windows XP as currently by default SAM is not supporting Windows XP.
Need to have update when some new software get install on Windows XP machine.
I don't think SAM is a good fit for your use case. There are other tools out there that do a much better job of what you're looking for. You might want to look at Patch Manager or Log & Event Manager.
